FAA studies falling drones.
Joined
Nov 27, 2017
Likes
3
#2
I don't know who wrote this but it's a complete waste of time: 34 mph isn't the issue at all - it's the terminal velocity that is the issue. What happens if a Spark's battery clip pops off (as there are countless recorded incidences of) and it drops from 120m (or potentially higher) onto a person's unprotected head? Death or severe head injury I'd imagine.
RaWine
Joined
Oct 25, 2017
Likes
48
#3
Looks like they didn't consider that. A smaller dense object is going to be different than an intact drone.
Upon searching news stories I found a man was killed by a 1 lb tape measure.
Tape measure falls 50 stories, killing man at construction site
Secure the heck out of the battery, or contact DPI maybe and tell them it's an absolute issue that batteries come loose before there's a big frickin expose' one day of people being killed and injured. Plus owner operator gets sued. No small thing.
Joined
Nov 27, 2017
Likes
3
#6
Rubber bands will stop the batteries from falling out, but a single motor failure, wire failure, esc, failure, software failure will still have the little brick falling out of the sky from up to 120m with no parachute.
Seanjo
Joined
Oct 26, 2017
Likes
17
#7
Joined
Nov 27, 2017
Likes
3
#8
I have decided to use a rubber band as a secondary safety measure. Whether you use a rubber band or a purchased plastic clip, I wouldn't fly with faulty battery clips because sole reliance on these items is far too risky. Batteries with faulty clips should be returned to DJI so they can learn the importance of not making rubbish.
Obviously, if you use an item like this, you need to be certain the band will not depress the off button. When I experimented, even if the band was directly on the button it did not turn off, but you need to check that for yourself.
Likes: Seanjo
Sparkzup
