Filmora editing tip!
Select "Use repeat frames" when working with transitions with trimmed media on the workspace.
Using "trimmed frames" (selected by default) will use what has been cut out as part of the transition even if the trimmed scene is deleted.
IE, if you go to the frame before a vibration or a camera jerk and cut it out, the undesired scene will be in the transition with "use trimmed frames" selected.
