Filmora Editing Tip
pmshop
Spark Pilot Guru
Fredericksburg, Texas, USA
www.youtube.com
Filmora editing tip!
Select "Use repeat frames" when working with transitions with trimmed media on the workspace.
Using "trimmed frames" (selected by default) will use what has been cut out as part of the transition even if the trimmed scene is deleted.
IE, if you go to the frame before a vibration or a camera jerk and cut it out, the undesired scene will be in the transition with "use trimmed frames" selected.
showatt.php
Thanks for the tip, really a nice app. Too bad you can't place media in the timeline without leaving gaps but I suppose that's not something you need to do too often (had to do it to sync audio and clips for a show I went to). Also no adjusting of the volume of a track like with Vegas.
You can adjust the volume.
Double click the audio track and audio properties appear above the work space
Volume is in there
Volume is in there
As well as fade in/out but that's overall, you can't adjust the volume up/down at discrete points.
