hi wifi
You cannot set it when you are connected with OTG cable. You need to start in wifi mode, set the band/channel and then connect the OTG cable.
Reactions: Kilrah
and the information tab?i don't have informtion because i am connect with otg?
Sent from my SM-G955F using SparkPilots Spark Forum mobile app
In the top bar, only here I see if it use 2.4./5.8G and it is correct.
In the "Image Transmission Settings*, I don't see right values, channels looks like for 2.4G. So this page is not correct and is useless.
OTG cable is not supported by DJI, this is why the trick of using it is far from being THE perfect.
Using OTG gives some limitation:
  • Cannot change wifi band. In IOS, on android it don't seems correct (looks like PH3).
  • No signal level indication.
  • Loss of custom buttons setup (for ios devices only).
  • Not officially supported by dji, so it could be removed.
  • Some says that RC cannot be calibrated ? (not checked)
  • RTH maximum altitude is 50m (not checked)
  • Shows the Joystick/GUI button at bottom left (not checked)
ShadesOn
