how to set radar and what parameter controls the gimbal speed
skinwalker
I am NOT interested in setting the gimbal sensitivity every time in the DJI GO app, can i use assistant 2 to set the gimbal speed? IF so which parameter do i alter? Also does DJI Go have a radar function? What does it do and how do I activate it? I see birds ALOT in my videos that i do not see at all while piloting the drone...be nice to have radar on my higher altitude flights.
You should not have to reset the gimbal speed every time you fly? I have set mine to 14 from the factory set 40 I think it was. I set it one time and forget about it. I found for what I do most want nice smooth video/photo the slower gimbal speed really makes a difference. But I have never had to reset each time I use the DJI Go 4 app. As far as radar function there is nothing within the DJI Go app that lets you see/track other things in the area if that's what your asking.
If you look at the specs, there is no mention of radar (Spark – Specs, FAQ, Tutorials and Downloads) so it's not there. However, they don't specify which type of sensors are used. That can be found here. Mainly ultrasound and stereo-vision. combined with algoritms to compute location of obstacles.
Just wondering: what would you do with radar? Considering the drone is flying in a 3D environment I think it would be almost impossible to display any data coming from a radar.
so wtf does the radar/sonar looking icon do?
also my question also was related to how to set the GIMBAL SENSITIVITY on the AC itself, not in the DJI GO app every single time i operate the drone.
Are talking about the attitude indicator that looks like a radar screen?
yes i now realize that after watching a video of it.... how do you get that to display and how to do you change your gimbal sensitivity setting in Assistant 2, what parameter?
It does look like a radar screen, but it only shows your heading relative you and due north , also your accelerometer reading , if your going forward at an angle , it will show you the angle, relative to the horizon , like on an airplane
Reactions: skinwalker
Yes, that's what it does.
No radar.
If you have the remote control, the thumb wheel is speed sensitive to the gimbal.
A light touch will move it slowly. Couple that with the settings in the go4 app and you should be able to have a smooth tilt.
If you put it in tripod mode, you have the ability to tilt the camera up past the horizon a little. This area of tilt is used for the Panos and Sphere shots.
You don't have to set the Gimbal every time. You set it once; it maintains that setting. I'm not sure why you think that you have to set it every time you operate the drone.
my app resets it everytime i close my tablet
Android or iOS?
OTG cable?
The settings should stay with the latest firmware installed.
There was a time when the cable wasn't supported and some settings had to be reset every time, part of the sacrifice of using the cable.
I assume you close the Go4 app before closing the tablet?
JerrellSed
