Litchi Question (Gimbal Pitch)
goixiz
I have a question on setting up mission with Litchi
Between waypoint I like to know how to use the interpolate function. Can anyone post a video or point me to where i can see an example. TIA
I just got started a few days ago and i noticed that something doesn't seem to be working 100% no matter what i do.. I'll come back if i find a good answer but keep in mind that , even a mission setup for the Mavic ( i forgot which one ) doesn't point its nose/gimbal in the right direction. it was a bit off. Like..it was already looking left when it should be looking forward...
Gimbal Pitch: Choose between "Disabled" where the gimbal pitch control will be manual, "Focus POI" where Litchi will automatically control the gimbal pitch to keep the selected POI in the center of the frame (blue markers), or "Interpolate" where you can specify the gimbal pitch angle at this waypoint. For "Interpolate" to work, the previous or next waypoint need to be set to "Interpolate" as well. Litchi will then automatically adjust the gimbal pitch angle to start and end at the specified angles, and smoothly transition while travelling between the two waypoints.
Find more Litchi Help Here:
Help - Litchi
Help - Litchi
Thanks for answers ad was very clear.
addtl Q, for POI. will the cam still point towards POI between waypoints ( i assume it does) during that (between wps) can i control the gimbal pitch ??
ChunGreenh
