Litchi RTH Procedure
Sparky4222
Good morning. I am in the process of running some tests using Litchi with my Spark. Until now I have been placing the semi-final waypoint of the mission in the general area where I want the drone to come down then another waypoint nearby at a lower altitude. I have purposely avoided using the RTH function.
My question is the following, does the RTH function in Litchi work the same way as in the Go 4 app? That is, the drone flies at the RTH altitude to the point designated as home and then makes a perfectly vertical descent to ground level. The flight I am attempting is in an area where there are a lot of trees and foliage and I certainly don't want to encounter Charlie Brown's kite eating tree taking a swipe at my drone.
Thanks.
Yes -- since RTH is a function of the drone itself. It doesn't matter which app you're using.
Reactions: Jointeffort
ChunGreenh
