Mavic Air propellers on Spark
carsco
Ok, you've seen the Mavic Air with the Spark propellers, but have you ever seen a Spark with Mavic Air propellers?
Not sawn propellers but ENTIRE propelles.
No ESC/motor desoldering, just install my mod and fly: only 5 minutes.
Less energy, less noise, more lift, more reactivity.
Reactions: graywoulf
Yes. Are 2 spacers 3d printed and longer screws.
No propellers needs to be cut.
Would you sell me the spacers and screws? I don’t have a 3d printe.
These are value taken from same flight.
7 + 4 minutes overing at home, no wind.
RPM difference between original propellers and Mavic Air propellers (same aircraft).
CURRENT difference between original propellers and Mavic Air propellers (same aircraft).
With Mavic Air propellers we have lower propeller speed (-2000 RPM!!!) and same current (at the end of battery it's normal a slightest current increase due to the lower voltage from 12 to 10.8)
Obviously we can reach highest propeller speed than original when need, like in strong wind condition, or when we carry a second heavy battery.
I've reached "Max Motor Speed" with original propellers at 16.000 RPM (with superlipo while I was in rapid ascent at 20km/h).
Maybe different with Mavic Air propellers.
Tomorrow I'll make a test with original battery and my superlipo (2200mAh 175gr)
Not so bad.
Not sure you shouldn’t be working at NASA! Thanks for the info. At my age I am amazed I am able to get my MA2 up in the skies but I love our hobby. Your technical knowledge and capabilities are way beyond mine. Keep up the good work.
Reactions: carsco
Thanks. It's simple because I use all the know-how since 2017.
I haven't invented anything.
I'm in this world since june 2022.
Today we've the 3d printers that help us.
Next step is an 3d printed arm extension to move away propellers from body for max efficiency.
Only a little extension cable from esc to motor needed for a rigid and stable arm.
Next step: Mavic Air motors, but are very expensive.
Reactions: ed1119
If you want one, now...
Send me a PM.
The kit consists of:
4 Mavic Air propellers
7 screws (one spare)
Ok, now I'm ready to sell the kit.
Here are a brief of mounting: no soldering.
Anyone could mount it in 5 minutes.
With Mavic Air propellers we have more reactiveness, less RPM, less noise and a LITTLE battery life increase (very slightly).
1StCoastMavic4
