Max Speed problem in GPS !!!
emo23
Bodrum-TURKEY
Hello All
As you see below picture my max speed in GPS mode is 2.9 m/s. No wind but very slow !!!
However speed setting is on max position.
I would like to fly more then 3m/s speed in GPS mode, note in sport mode. Any idea ?
By the way howto:parameterhacks [dji.retroroms.info] site says GPS+ hack mode.
Anyone tired those paramaters for speeding up in GPS mode ?
Thank you
Hello All
Thank you
Hello from the Hoosier Heartland emo23.
Is the Obstacle Avoidance turned OFF?
The Spark will go a bit faster in normal mode.
I haven't tried changing any parameters but others here may have.
Use the search function of this Forum for more information.
I'm pretty sure I have read about it here before.
Good luck and welcome to the Forum.:cool:
I ll disable Obstacle Avoidance and try. Let you know
By the way I changed parameters as on my first post. Nothing is changed.
Thank you.
Yep. As nearly all my flights are high up, I always turn off OA. As others have shown, it doubles your speed without the gimbal tilting as in Sport. If you dare to use the Mod version fo Go4 on Android, you can use Cinematic mode, which gives you the speed of Sport mode with the gimbal stability of Pmode. Just be carful if you do, as the braking is much more relaxed.
As Spark 317 mentioned, I believe the max speed with OA enabled is 3m/s
3m/s - Pmode w/ OA
6m/s - Pmode w/o OA
14m/s - Smode no OA
The above two replies very much sums it up.
