New Spark owner with a few questions :)
WillSparky
I got my FlyMore Spark yesterday, in anticipation I've read the manual twice and watched all the tutorials (and more) several twice. I did flew a bit yesterday as well and it was fun!
I do have a couple questions I fell experienced pilots might be able to help with ;)
First, how does the drone handle a sudden change of elevation. For example if launching on top a building a or a cliff and flying past the edge.
The first time I did a "dronie" quickshot, a slider appeared at the bottom of the screen for the distance to fly back and away, (I think). Now it no longer appear and i can't find it in the settings, where is it?
On the WiFi screen, I've seen screenshots where you can select between 2.4 and 5 band, on mine it's only showing 2.4. I am in the US using the controller. Is that normal ?
Finally, is Palm Landing supposed to work all the time or only in gesture mode?
Thanks to anyone willing to help!
The Spark will treat that scenario just like when you fly over level ground since it's not aware of the ground.
You'll only be able to select the channel if your mobile device is connected to the remote controller via Wi-Fi (and not an OTG adapter).
Palm landing will only work if you have Advanced Gesture Control enabled. If that's disabled, you could still land on your palm (like you land on the ground) or hand catch your Spark and hold the throttle down until the motors stop.
Reactions: Kiteboy
you can tilt the spark sideways and the motors will shut down
Thanks! I found out it will palm land if I select "gesture" as the flight mode which is fair enough.
If any one is wondering, I did find the slider for the Dronie fly away distance setting. It appear is you long press the "Dronie" icon once that mode has been activated.
In my case it deposit work anyway and Spark just flys back for ever until I stop it.
Will only give you distance or height also? Some people were disappointed that it wasn't going high enough.
csdisme
