- Join
- Feb 10, 2018
- Messages
- 34
- Age
- 37
*EDIT* sorry for any confusion guys, I will clear this up now...
Its NOT the fan I hear when the drone is cold. When the drone has been flew and I then go ahead and recharge the battery via USB as I plug in the USB I (THEN) hear the fan for a second then it shuts off.
So just to clear confusion and make it clear to understand:
The drone now has been sitting over night with 40% charge. If I plug in the USB via the drone now (while the Spark is cold or has not been flown) I do NOT hear the fan for that split second like I do when its warm or has been flown and I charge it just after its been flown)
Now, I do hear a slight power sequence as I plug in the USB to charge the Spark when its cold but its not the fan.
Now, if the Spark is warm from a flight or the Spark has been sitting charging for 5-10mins via USB and I THEN take it off the USB charger and put it BACK on the charger via USB right away (in a split second) the FAN boots up for a second and then charges normally.
So, when its cold and I charge it via USB (no fan but a slight sequence as power hits main board).
When WARM or Spark has been charging for 5 mins I turn the charger OFF and ON again AFTER its Warm OR has been charging for 5 mins - fan boots up for 1 second and shuts off continues to charge normally
Again, I have explained this as best I could.
If anyone has experienced this or know. Please comment.
