- Join
- Mar 30, 2019
- Messages
- 63
- Age
- 55
Hi guys, I heard that during RTH spark can sense obstacles only if it is less than 100m of distance, it is true? And if it is true, why spark shouldn't be able to sense obstacle in RTH further than 100 m?
So does it return in sport mode? I'm confused cause someone say that it crash in the obstacle, someone say that it avoid the obstacle if it is less than 100 m of distanceWhen you press RTH obstacle avoidance is turned off (due to it returning at sport mode speed, I believe). That's why you should set your RTH altitude to avoid any obstacles.
Yes, but do not trust obstacle avoidance.Hi guys, I heard that during RTH spark can sense obstacles only if it is less than 100m of distance, it is true? And if it is true, why spark shouldn't be able to sense obstacle in RTH further than 100 m?
Max speed in Sport-mode is about 14 m/s..Presume 10mtrs/sec is Sport mode? Great advice on over water with override available.
