Spark will NOT fly straight in Sport Mode
JS1500
My Spark will not fly straight in Sport Mode. Both the video feed and the actual video recording show that the drone itself is flying several degrees off of where the center of the screen is when I'm going full stick forward in Sport Mode. I'm not sure if this is a problem with the gimbal, a problem with the drone itself, or merely the drone's flight being impacted by slight wind gusts. I have brand new props and I have current stick and IMU calibrations. Can anyone shed light on this? This is the one thing that has bothered me most about my Spark.
Mine has always done this, I think it's something to do with how small it is when it hits a bit of wind, I was flying mine the other day in sports mode and it was flying angled at first I thought I had my stick pushes forward angled but it wasn't it was the way the Spark was fighting against the wind.
And my Spark has a feature if I'm pushing up altitude and pushing forward in Sports mode my Spark flicks too the right and back straight again it use to bug the hell out of me, I calibrated everything and it kept on doing it so I just learned to live with it.
Crabbing it's called the Spark is notorious for doing this in the Wind.
Mine does it without wind
I see it a lot on RTH and Litchi Missions when I do a POI.
POI pin where I want to focus has always been a few degrees off from actual.
Focus here is the top of the hill with a waypoint 0:00 to 0:16:
It's really noticeable in that video, and that's exactly how my footage is too. It's extremely frustrating that this drone can't fly with it's body oriented exactly straight where I'm telling it to go.
In Sport mode, GPS positioning is off. Edit: Only in ATTI mode is GPS off. (My mistake, sorry) Your aircraft is now fully independent of the ground and everything is relative to the air. If you were to hoover, sticks neutral, even the slightest breeze will cause your aircraft to drift, relative to the ground. Relative to the air, it is not moving. A more massive aircraft simply has more inertia and takes longer to match velocities with the air.
Crabbing is a basic principle any pilot learns for navigation. Watch some "cross-wind" landings on YouTube. It can be a hairy experience.
Reactions: graywoulf
In Sport mode, GPS positioning is off. Your aircraft is now fully independent of the ground and everything is relative to the air. If you were to hoover, sticks neutral, even the slightest breeze will cause your aircraft to drift, relative to the ground. Relative to the air, it is not moving. A more massive aircraft simply has more inertia and takes longer to match velocities with the air.
I understand this, but that still doesn't explain why my Spark is essentially not flying in trim. I understand that the aircraft will drift with wind when in Sport Mode, but even if drifting, it should be flying in the same direction that the center of the camera is pointing.
Without actually seeing what you're describing, it is difficult to troubleshoot. However, I'll take another stab at it.
If you were to look at a video recorded with a cross wind and the aircraft has only forward pitch input, the aircraft will fly in the direction the camera is pointed. The air mass is moving sideways and the aircraft with it. The ground will appear to be moving sideways to the aircraft (as well as forward) and it will appear to the video that you are panning sideways.
This would apply to ATTI mode as well as Sport. Flying in GPS mode eliminates this (mostly) as all inputs and flight path are relative to the ground.
Again, sorry if I'm off base or sounding patronizing, not my intent.
Reactions: Andre Levite
He states there was zero perceptible wind but I think you are correct.
The pilot may sense no wind on the ground and see none in adjacent tree tops but the aircraft still may react to localized cross wind or other turbulent air.
I've also seen this phenomenon corrected by swapping out for new props [above]
Agreed, there is rarely absolutley zero wind velocity. As for the props, could potentially be the issue.
No, in sport mode GPS positioning is ON.
What you describe, is ATTI mode.
I think you should make some tests.
First fly one direction. Check the video to see if spark drifts right or left.
Then fly to the opposite direction. Check if it drifts right or left. If it drifts to the opposite direction than the first flight, it drifts with the wind.
Post some video here to show the problem, and upload your flight logs, to be checked by someone experienced.
How would y'all recommend uploading a clip on here? I have several that are mp4 format, but for some reason it won't let me attach it.
Create a YouTube or similar channel and upload your content there.
Copy and paste the link back to the Video / Photo section for us to see under a new thread you create.
Photos may be directly uploaded, but not video.
I have this problem too and still haven't been able to solve it after IMU, compass calibrations or propeller change/swap.
This assumption is actually true. I don't have a video to show this. But I found from the attitude indicator in one of my flight logs that the SPARK is tilted towards one side when flying in one direction and towards the opposite side when flying in the opposite direction. And since this discovery, I have stopped raking my brains over this issue.
