Spark with FW .600 / .400 should i update or not?
JeyTea
Hello Folks,
i have not made any update on my spark since the 21st August 2017.. so the current FW is as follow:
Aircraft Firmware: V 01.00.0600
Remote Controller Firmware: V 01.00.0400
Since everything is working fine for my needs, i do not see any reason to update.
But how is your opinion and how are your experiences to that?
What do you recommend, should i stay with it or should i pull the trigger and do an update after such a long period without updating?
if i was you i'd stay on that firmware, ive been havin nothing butb problem's on the new 1000 firmware and 21 go4 app on my Samsung s8, it started off really well the first day flying after updating then the connections and disconections started its bad. when flying even about 20 feet from myself its disconnecting and connecting then losing it again. So im going to go back to 300 firmware that everyone swares bye thats the best firmware for the Spark.
the .300 FW was the first FW Update after Spark Release right? How will you manage that? In can no more downgrade since the .600.. :(
I used dumldore to downgrade to 300 firmware using Android as well
BuckGregor
