Sphere Photo - I’ve almost got this..
freerange
Hi Guys,
Apologies if this has been discussed before.
I took the spark up today;
Selected Sphere. It took the 46 images.
And I used the DJIGo4 app to stitch the images.
I am very happy with the result. ( just a quick backyard lift off with some wind)
BUT,
When I want download / share / save / export the image;
I only get this;
Besides making a screen grab of the original, is there any other way of getting the sphere hi res image to my phone?
Thanks,
Pierre
You can either download the sphere from the drone once you have stitched it. Or you can Load the panorama images into something like THETA+ app or the Tiny Planet App or the microsoft ICE program.
Hi Guys,
BUT,
I only get this;
Thanks,
Pierre
Check this out from November 2017.
It may help.
Tiny Planet Tutorial Part II: New DJI Sphere Pano + Microsoft ICE
Thanks,
I’ll look into those app’s. I have ICE on my desktop but haven’t completely figured out all the options yet.
I downloaded the sphere from the drone but this was the result;
This pictures in 2:1 ratio are typical for 360° pictures and can be used for the most things (VR apps etc.) I use ICE too because the quality at the end is much better. There are a lot of great tutorials on youtube. If you want the faster way you can use 360° viewer (P360 etc.) an load the 2:1 in the app and export it as a tiny planet
I use the Theta+ app and it's fairly straightforward. You open the app, find that "flat" panorama that you downloaded from the DJI Go app, and edit it as a tiny planet if that's what you want.
Thanks,
Hi there, I have watched several tutorials on YouTube and read many posts as to how to make the interactive 360 pano work. The easiest method I found is described below.
Download the stitched image to your PC.
Go to theXifer.net - Just a Web Based EXIF Editor for Local, Cloud, Flickr, Bootstrap
Upload your image.
Go to the tab "XMP GPano Tags" and enter the following -
ProjectionType: "equirectangular"
UsePanoramaViewer: "true"
Close the editor and download the image.
Now if your phone is compatible, you can open the image from your Gallery and you will get an interactive 360 degree experience.
Otherwise, you can simply upload the image to Facebook or Google photos to get the interactive experience.
NoeFolk502
