USB car charger??
Ah yes, it's very expensive though, you really need to be out in the boonies with no power around to have a use case for it ;-)
The HP Pavilion dv6 has a 90W power supply so I will suggest the 200W inverter since inverters run quite hot at maximum power. Keeping it under 50% draw will keep it cooler.
One piece of advice here, have a hard surface for the laptop to set upon - sitting it on the seat next to you may block the intakes causing it to overheat.
arshadkhan
