Video not level when i turn or yaw with spark
BushPusher
Some what new to the spark, but i have noticed that when i yaw or rotate left or right the video will tilt for a second or two
Is this something i am doing wrong , i am still in the learning curve just let me know
hoping the spark it is fine i did buy it used
Roger
Spark 317
Indiana, USA
Roger
In the Go4 app under gimbal settings, be sure you are in Follow mode and not FPV.
Also, if you fly in Sport mode, the gimbal will show a noticeable swing in the video captured.
Good Luck. 🙂
Reactions: RotorWash
BushPusher
Thank You Spark 317 i will have to check the gimbal setting.
As far as i know i am not in sport mode i will check on that as well
if in sport mode would that not have a notification on the screen ?
Thanks everyone
twickers14
SW U.K.
You’d know if you were in Sport mode-she moves real quick and obstacle avoidance is disengaged. Advice above is, as always, spot on.
Brian Snyder
I believe there is a setting to adjust the horizon tilt. Go to YouTube and search to horizon tilt adjustment.
Speed750
I think you might be fighting the wind. If I hover with a strong wind the horizon will be tilted. That's the spark trying to stay in one place. On super calm days I never see it.
Sean_OL
