Video randomly stops recording, won't start again
Bogiewon
Hello!
I'll start recording a video with my spark and then it will randomly stop and then won't start again. I haven't done much troubleshooting yet but wanted to post here to see if anyone else had a similar problem.
I have two batteries and it always happens with only the first battery - I haven't tested to see if by chance in always using the same battery first, bit I never have the problem after switching.
I have my cache size set to Auto.
Any thoughts? Thanks!!
Definitely didn't run out of space - worked fine after I switched batteries, plus I always download and erase after each flight. I've also already done a format on the card and still have the same problem.
Here is a list from DJI's site of compatible SD cards.
Maybe you need a faster card?
I ordered a new card, should be here tomorrow. I'll let you all know if it fixed the problem.
HungSpring
