- Join
- Jul 7, 2018
- Messages
- 9
- Age
- 46
You need a remote to start the motor without launching it. Try using the auto takeoff on dji go 4.Bought a spark today, had it on charge for 4 hrs and just have 2 leds that flash on the battery 4 times then a pause then this just repeats, I try to swith it on by double tapping the button and holding the motors make a noise and that's it, it just won't do anything then, any thoughts?
None of the lights on the drone come on and can't connect to dji go 4You need a remote to start the motor without launching it. Try using the auto takeoff on dji go 4.
Mine power up if the battery is charging in the Spark.Unplug the charger it won't power up while charging.
Not tried mine since I first got it Christmas, but I had the same problem. Unplugged charger pressed the battery button 2 times holding it until 3 set of beeps turned it off and then back on and paired with android and also me ipad. But haven't tried with charge cable since latest firmware up date. Could it be it's still running an old firmware ??Mine power up if the battery is charging in the Spark.
You cannot take off, but it can be turned-on.
1. You can't power on while charger plugged inBought a spark today, had it on charge for 4 hrs and just have 2 leds that flash on the battery 4 times then a pause then this just repeats, I try to swith it on by double tapping the button and holding the motors make a noise and that's it, it just won't do anything then, any thoughts?
