Connecting RC to spark
I've been curious of that myself. Not sure on the answer but I've been told by DJI in Bangkok that I should use the OTG cable.
BUT! I will tell you that I was flying the other day using the OTG cable and my aircraft somehow got disconnected at a thousand feet and began it's RTH function. Fortunately the function worked great and the drone came home, unfortunately for me I was in a long tail boat shooting over water and had to make a water landing save by catching it while I was swimming. I'm not sure if there was a bad connection between the OTG cable and my phone or what but I don't think I'll be using the cable anymore after that incident.
The latest firmware has a return to pilot option. It uses your phones GPS to come to you and not it's launch point.
I fail to see how WiFi com between the phone and the transmitter can affect the connection to the drone.
Drone to the phone only is another mater.
There are a few YouTube reviews on this subject and those I have seen confirm my prediction.
As I said in an earlier thread, check the SD card for formatting issues as this can affect the Spark. If it can't record a log it has a problem that effects the firmware operation. You can try this yourself. If you remove the card or reformat the card, the problem goes way.
