Hold your horses, mate!
You're good then... aka FCC mode.
Enjoy your flights
I really think its not? it has more than 11 channels and range is still quite bad, only 300 meters, shouldnt i be getting more like 2000 meters. Im flying countryside.
Okay, your doing FCC mode and using a channel in the upper 5.8 Ghz band.
And connected to device via wifi, right?
We prefer to choose a channel in the lower (1-11) 2.4 Ghz and OTG (on-the-go) cable between device and remote.
Channel is choosen manually and drone need to be powered off/on again to activate new choosen channel.
Cable is prefered over wifi to reduce risk of interference and less video latency in-app.
There is a ton of descriptions in this thread on how to do this..
yes and yes. I have my otg cable coming in the mail. I tried to choose lower channel, the one with the highest bar, is this right one to choose? but it did not work and my drone didnt connect anymore so i had to reset it.
Lowest bar!
I had to use a different patched version of djogo to make everything run in 2.4Ghz mode, the mod version would always switch back to 5Ghz if I tried to use the mod version to switch, once I got it switched over, I can now fly in 2.4Ghz mode with mod. I think it was the 4.1.3 that's quiet widely available.
There's also a specific way of doing it, you need to boot the quad, boot the remote, connect to the remote by wifi, change the wifi settings, click apply, click restart wifi, wait for everything to reboot (the image on your phone will go grey when everyone disconnects and reboots then the image will come back), then connect the OTG cable (don't connect it before at all, you may find the screen goes grey again briefly while the remote switches to OTG mode) You should then find everything is running in 2.4Ghz mode and next time should just startup as normal (start quad, start remote, connect OTG cable on green light).
Reactions: Haggi
DJI GO 4 MOD 2.0
  • Auto enable screen rotation
  • Red Status and Nav Bars
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
  • Sphere Pano Support
  • DJI GO 4 Ver. 4.1.15
Downloads
DJI GO 4 MOD 2.0 - Download
DJI GO 4 MOD LITE - Download
Changelog
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
DJI GO 4 MOD 1.1.1
DJI GO 4 MOD 1.1
  • Fixed Google Maps
  • Keep Screen On Added
  • Added Auto 100% Brightness
  • Added Auto-Rotate
DJI GO 4 Mod 1.0
  • Initial Release
Tested Devices
  • Nexus 6P - Android 8.1
  • Nexus 6 - Android 8.1
  • Mate 9 - Android 8.0
  • HTC U11 - Android 7.1.1
  • Samsung S7 - Android 7.0
  • Sony Z3 - Android 6.0
Credits
PayPal: [email protected]
Also works very well on Huawei Mate 10 Pro. Except for the Follow Me mode, but so have several others already declared.
Reactions: Haggi
bonjour à tous,
nouvel utilisateur de spark, j'ai étudié la notice en francais et une petite question me turlupine ;-)
il est noté pour un RTH :
"upload_2018-6-22_17-4-3.pngupload_2018-6-22_17-4-28.pngupload_2018-6-22_17-4-42.pngupload_2018-6-22_17-4-51.pngupload_2018-6-22_17-4-59.pngupload_2018-6-22_17-5-8.png
upload_2018-6-22_17-5-22.png upload_2018-6-22_17-5-36.png"
qu'est ce qui est sous-entendu par "il atterrit automatiquement" ? il revient exactement au point RTH enregistré et se pose sans que l'utilisateur est besoin de le forcer ?
Hello, i Install the Mod App but the Mod Go4 didnt show the Google Maps location, why???
Yeah, i get back on you when i have reinstalled and tested. I dont see that, mine shows channels from 1 to 11 and then the 149 etc. And is currently on 149.
Edit: do i have to reset the drone and controller before connecting to the reinstalled app?
You are fine you are in fcc mode don't uninstall....
5.8 ore 2.4 is fcc? My English is not the best what is also imposant to change in the mode app? I am from Germany. Thx
I'm on the same setup but with Xiaomi Mi MIX. Yesterday reached 950m distance at low 40m height until first video link issues (quality, not disconnection). More than enough, so I turned back. As comparison, original app allowed to fly...150m and disconnected...
I flew 400m with original app and otg without problems in ec mode.
Set your phone in Flight mode (no WiFi).
Turn on your Spark and RC, and wait for the green light on RC.
Then run DJI GO 4 app, and connect your OTG cable. You should be "connected" and have video feed through the cable (WiFi is turned off).
Follow your instruction not working, with wifi on it works well.
I think I can't go in fcc mode here no 11 channels available View attachment 5482View attachment 5483
You are in FCC mode, if you were in EC mode you would have 1-13 on the 2.4ghz channel band not 1-11 (the 149+ channels are 5ghz frequencies).
Your system is just working in 5Ghz FCC mode (that is why 149 is in blue), if you want to change to 2.4Ghz follow my instructions in my previous post.
OK? Cool, but why Google Maps don't working? I try Offline Mode but didn't working too.
foodeater
