Oke new version (30 days from now available) Uploadfiles.io - Download 4.1.15 Spark with offline Heremaps maps from I.apk for free
deleted old one, set phone or tablet offline(airplane mode)
install app, sign in with name: A and password B
after install closed app, set to wifi or internet and start go app
go right above to menu, and download offline map. closed app.
Now to fly: Start RC, start Spark, put OTG cable in RC, go app starts, check your settings and fly.
fly safe, you have FCC power, and all the Mavic Pro flightmode available(inc waypoints)
cheers
Is there way to disable the initial full brightness in the moded app? This prevents Galaxy Note8 to go to max brightness 1200nits
have to every time it strats re-enable Auto brightness :(
Thanks
cheers
What ver is this, MOD Lite?
cheers
Did a few test flights with this version and the app randomly freezes and crashes during flight. I am using a Samsung S10 on the .0300 FW on my spark. Just now the app crashed while I was in sport mode and the drone began to climb vertically and did not respond to my inputs. It was a bit scary, although once I switched back to regular mode it finally responded and I landed the drone safely. Phew!
Previously I was using this same FW .0300 with the official DJI Go 4 app without any app crashes.
When I installed this APP it did not install along side the official app. I had to delete the official app. Now I might revert back or hopefully find another Download link to the other versions posted on here.
Reactions: lifeisfun
Thanks for sharing!
I don't know of this version works with the newest android version like the S10
Disable Battery optimization for the App, that should help.
Thanks for the feedback, it's the best version ever.
Also TIP: for flying waypoint missions with your Spark, you can install dji go mod missions next to this app. You can make your waypoints missions in advance/save and when GO started your mission is showed into this GO app.
Tried to install 4.1.15 alongside the legit dji go app on my S10+. Installation fails. App Not Installed.
Any ideas?
TamikaT436
