dji spark external charger
Jaski
Hi guys,
I am aware that the dji spark's battery can be charged using the usb port of the quad itself, however, I am interested in charging my battery while disconnected from the spark using again a micro usb.
The reason is that I would like to carry around my powerbank and use it to charge my spark's batteries which are not directly connected the aircraft. Is there some device that converts the power from a powerbank and transfer the energy into the LiPo?
Thank you in advance.
Regards,
Jaski
Hi Bennie,
Are you sure about that? Have you actually tried?
I've tried quickly and it doesn't work. In addition, according to the following post, it's not possible as the micro usb is only for firmware updates.
Spark USB Battery Charging Hub
J
ShadesOn
