Home Point Updating..!!!
Spark 317
Joined
Jul 10, 2017
Likes
596
Location
Indiana, USA
#3
If it happens right when you launch after starting the motors, it is normal.
When I fly my Spark, I turn it ON, let it sit and collect the GPS info and wait for the status bar to go green before starting the motors.
Sometimes you'll hear a Home Point update after it collected the information and then again at launch.
If you use a device that has GPS, I believe you can update your Home Point as you move about with the controller or set it for auto update?.
I have WiFi only so haven't tried it yet myself.
Likes: DiP
Spark 317
Joined
Jul 10, 2017
Likes
596
Location
Indiana, USA
#5
That's good.
I would be concerned if you did I not hear it.
It's good to launch and go up about 25' and hover for a few seconds so the bottom camera can look at the launch site, which will help in a RTH scenario.
Likes: DiP
John Harvey
Joined
Feb 1, 2018
Likes
51
Location
Croatia
#9
After the motors have started I wait a few seconds, then lift off to a few feet, only then do I get the Home Point updated message. I Never fly off until I get this conformation!!!
jleone15022
Joined
Jul 19, 2017
Likes
47
#10
If you set the home point before taking off, then ascend to at least 30 feet, when you engage RTH, the Spark will use "Precision Landing." You will even see a message on the Go 4 app and the Spark will move quite dramatically during landing. I use this all the time and I get within just a few inches of where it took off from.
Likes: Hddeuce03
Stronzo
Joined
Apr 7, 2018
Likes
#13
The home point will be automatically set assuming the Spark is able to connect to enough satellites. Look for the "H" symbol on the map in DJI GO to confirm the home point has been set.
Thanks for your prompt response. I thought that the Home Point was something that could be set manually too, before taking off.
jdi
