HOW TO: Change the Wi-Fi frequency and/or channel
msinger
DJI Drone Expert
Approved Vendor
Harrisburg, PA (US)
spark-help.com
When connected to the remote controller or Spark Wi-Fi network, follow these steps to switch to a different Wi-Fi frequency and/or channel:
1) Connect to the remote controller or Spark Wi-Fi network.
2)
Start DJI GO.
3) Go to the "Wi-Fi Settings" section of DJI GO and select "2.4G" or "5.8G" (depending on your desired Channel Mode).
4) Select the desired Channel Index:
Note: You'll be disconnected from the Wi-Fi network after selecting the Channel Index.
5) Connect to the remote controller or Spark Wi-Fi network.
6)
Go back to DJI GO and verify the new Channel Mode and Channel Index selections.
Today I had one of the worst days, I had to run down my road after my spark as it had lost signal from my mobile phone and since then I've been getting a poor radio signal warning. A problem I've discovered is, I buywant to change my channel to a more solid and secure one with no disturbance but there's no signal strength bars showing while my AC is connected so i can't see what's going on so I can't select a proper channel. What can I do to solve the no bars showing problem?
Reactions: Junebug
