Yes, you won't be able to do active tracking since you need a "cellular" device although it doesn't have to be active but it will only leverage the GPS chip. Without that you can still use it to do everything else.
Yeah sorry yes whichever one is the one that uses GPS to follow you.Huh? I don't understand what you are saying here. I use an iPhone 6plus that does not have a SIM (no cellular) and I can still have my Spark active track fine. Active track doesn't use the phone's GPS chip remember...you circle the target that is being tracked. Maybe you are thinking of "follow me mode" like the Mavics?
The biggest con to using a Wi-Fi only device (or a device where the cellular service is deactivated) is that you won't be able to use features that require an Internet connection. For example, that means you will not be able to download the maps in real-time. You could cache the maps in DJI GO like this if you need to use them. Or you could setup a hotspot on a mobile phone and connect your iPad to that Wi-Fi network (which will share the Internet connection).If I use an I pad wifi no cellular is that OK?
The Spark does not have the Follow Me flight mode. GPS on the mobile device can only be used to reset the home point to your current location.Yeah sorry yes whichever one is the one that uses GPS to follow you.
You may be able to if using OTG, but Wifi won't connect to two places at once.Can the ipad link to your cellphone while flying like a hot spot?
Yep. The Spark runs the same version of DJI GO, so that information also applies to the Spark.I realized it was referencing Phantoms and M-Pros
It's not available in all versions of DJI GO. As noted in that post, you can roll back to DJI GO 4.1.15 to access that feature.Off-line maps isn't available from the Go4 menu.
It does not.Do you know ifl Spark/Go4 recognize that map?
Thank you. I was hoping that "something" changed with 4.2.6Yep. The Spark runs the same version of DJI GO, so that information also applies to the Spark.
It does not.
