My Spark almost hit a tree
IPedro
I was flying normally (Height: 80 meters)
Then I lost connection and RTH was triggered. Then, the spark didnt go up 30m, as programmed, and it flew straight. Almost hit a tree. Why didnt it go up?
Since you already exceed 30m, then it directly going to home point.
30 m is minimum height that user can set, but if it already exceed, then spark will not ascend anymore.
It's not true actually.
If it was true, then rth altitude setting would be useless.
You can set higher than 30 m if you like, but it works like that, so you specify MINIMUM height for RTH, and will Go to that height if it below your setting, but if it already higher then it don’t decrease the height in order to RTH.
Try read the PDF manual in your phone again.
You mentioned altitude, but you didn't mention distance.
Also, you didn't mention rth settings in go4 app.
Rth procedure is a little complicated, and is dependent on settings, distance and height.
i’ll definitely need help. I can give to you the flight logs. Can you help me please?
try setting it a higher setting . if i am reading what you said and if you are flying at 80m and you set at 30m that is 50m lower than what you set it at .it will not go up another 30m that's not how it works . it's from when you take off ground zero .
one other thing , how high are the trees where you fly 340 plus feet ?
Reactions: rich777
akane13
