My iPad mini won't fit in the Spark arms. I'd have to shave the upper part of the arm to get them to open more. I use an external holder which sits above the controller (same one I use on Mavic so I can see controller display) So it has to be at least 10 inches. I pre-ordered one from the DJIcables.com guys.It is just long enough as you can see in the photos below:
Hi Jim,Well the Rantow one piece iPad Mini 4 OTG cable just arrived from China and it works just fine. It is just long enough as you can see in the photos below:
View attachment 479 View attachment 480 View attachment 481
Thanks. Do you see the map on the iPad mini when you don't have a wifi connection?I'm using my DJI Spark w/ the iPad Mini 4 plus mount -- my cable isn't from Rantow but Anbee and that one works fine as well despite the fact that it says "NOT FIT DJI SPARK" in the listing. I'm bringing this up because the Rantow one has been out of stock for a couple weeks or more now. Looks like they finally restocked it, but anyway, here's how I do it similar to animal's instructions. Hope this helps someone because by doing it this way it works -every time- for my iOS devices.
If I’m not mistaken that isn’t actually an OTG cable, rather it is just a micro usb to lightning cable.
I cache maps I google maps but not in the Go4 app. Am missing something?Technically correct! But it still uses the whole On-The-Go standard/specifications (I believe) for the communication itself. It's just more direct to have a micro USB to lightning cable for our Spark purposes.
Yes! I have iPad Mini 4 cellular version but with NO LTE data service. Map data needs downloaded/cached in advance. On iOS this process is a bit ridiculous because you have to look up the area you'll be flying and scroll around with your finger to "cache" the map... compared to android where, you know, you can just dl the map.
yeah -- sorry for the late reply. so, basically you need to be in the Go 4 app and make sure to have the "cache map data in the background" feature turned on. you then have to physically scroll your finger around the area you plan to fly until the map appears. This requires you to do this when you have an internet connection BEFORE you fly in a location. It sucks, and the cache also gets regularly cleared so you'll need to keep doing this. I really hope that they allow us to download all of the map data the same way you can on Android devices soon.I cache maps I google maps but not in the Go4 app. Am missing something?
Thx. It doesn't help much when one is travelling and ipad is shut down during transit. I may try my phone's hotspot as a work around.yeah -- sorry for the late reply. so, basically you need to be in the Go 4 app and make sure to have the "cache map data in the background" feature turned on. you then have to physically scroll your finger around the area you plan to fly until the map appears. This requires you to do this when you have an internet connection BEFORE you fly in a location. It sucks, and the cache also gets regularly cleared so you'll need to keep doing this. I really hope that they allow us to download all of the map data the same way you can on Android devices soon.
DJI Spark / Mavic USB OTG Cable for spark Controller to ios device (iphone/ipad) | eBay i bought from ebay can used for ios deviceI have a question. I read the entire Spark manual but it does not mention using the OTG cable to directly connect the RC to the tablet. I have an ipad mini 4 cellular. It works fine, can connect and have flown when the ipad is connected to the RC via WiFi. But as soon as I use and OTG cable to connect the ipad to the RC it shows the Spark as being disconnected and of course I get no video from the Spark. It does have the green light on the controller but DJI GO 4 shows the Spark as being disconnected. I have tried airplane mode as well as just WiFi turned off. Bluetooth has always been off. I have even tried a different Apple cable to the ipad. Being i know absolutely nothing about Apple I'm guessing it is possibly a setting. As soon as I connect the ipad to the RC via WiFi I see the Spark fine and have flown with it that way. Just can't seem to get the direct cable method figured out.
Thanks
Between step#2 and #3, after you turned on the RC and it connected to the Spark; do you wait for the mobile device to connect to the RC through wifi and then #4 turned off the wifi and bluetooth?
does this OTG cable still work with the latest firmware on the spark ?
Yeap I get this too but dont seem to effect anything.I occasionally get a "this device may not be compatible" warning, but it works OK.
