SD Card help
Trevor81
So with all the variations of microSD cards out there (SDXC, SDHC, Class 10, UHS-I, UHS-III, A1, U1, U3) looking for recommendations. Will probably be getting a couple of 64gb's.
Thanks!!
I use Sandisk extreme pro 32gb and it works great. Not sure it is worth buying the 64gb for this purpose. 32gb will record some 20 flights. Your call.
Personally, I try to stick with the U3. They have the fastest write times so they are fine all the way up to 4K recordings. And remember, the Spark may not give you 4K vids, but it has a very high quality camera that just crops down because of the 2-axis gimbal... so the faster the better... why skimp on the most important reason you have the drone in the first place! :)
Reactions: ELD.visuals
