SD Card Slow
Yaas
Hi all
Hoping someone can help with this & apologies if it's a silly question
Been doing some videos with my Spark but most times i get a message saying "SD Card Slow for 4k video" & it stops recording or just will not stop recording
Any idea how I can fix this?
Amazing drone otherwise
Thanks in advance
You mean the Go4 app give you that message ?!?
Did you use the official latest app version?
What model of card are you using ?
Slow for 4K? It's only a 1080p camera video wise.
What micro SD card are you using?
Yep
I know that
Hence why I don't understand the message
I'm using a KINGSTON 32GB Micro SD Card SDHC TF MEMORY CARD CLASS 10
Any idea?
Did you tried to reformat it in something else than Spark and then again in Spark ?
Maybe you can also try another card.
I've formatted it in the Spark
I'll format it in my phone & see the result
Thanks for that
Just an idea from another thread.
Hi guys
Still getting that message come up
Then it stops recording
Takes a while for the record button to get highlighted again
Then when it's eventually highlighted,it doesn't come off recording unless I exit the app
Doing my head in
Did you had the chance to try another memory card ? Maybe this one is just bad and the Spark is fine.
Reactions: Kilrah
I am using some SanDisk Ultra 16 GB class 10. But normally any Class 10 uSD should be ok.
ariadef
