Spark overheats
vlaporte
My Spark overheats and gives error code - barrometer error due to overhearing. IF you fly immediately it stays warm but not hot.
If you turn on and not fly it gets very warm on top of drone - not battery and get above error.
I took top off and to view fan and heat sink - now stays just warm not hot and no error code and flys fine.
After reviewing many posts about "hot Spark" I decided that the cooling fan needed more intake air to cool properly. So I drilled an array of air intake holes in the top shell of my Spark.
Now it stays cool even at rest (power on but not flying).
I also bought a micro USB to iPhone cable which makes setup link (controller to iphone) much easier - just plug in - no wifi setup period.
Happy Landings,
Vince
Reactions: DaysOfNoah
Hello from the Hoosier Heartland, vlaporte.
That's a modification I hadn't seen before and apparently it solved your problem.
Thanks for sharing and welcome to the Forum. ?
michalszwed18
I inspected the fan system - the 4 ports (2 on each side) are all
exhaust ports but their are no visible intake ports.
After my mod a notable exhaust
breeze is evident on all 4 exhaust ports and top of drone is much, much cooler.
Thanks,
Vince
Happy Landings,
Vince
I know this is an old thread, but here goes : If I have the cable from teh phone to the controller do I still need to set the phone on the spark wifi ?
LuxVitae
