Device disconnected
Chandler
Using my iphone I have put in the password etc.. Spark registers and says I it is connected wifi..etc. But the app itself will not connect, even when I choose SPARK as the drone ( I also own a Phantom 3 Advanced) Any ideas?
Are you also using a RC?
Can you be a little more specific about what you see in your app. In the main screen you should see a blue button START FLIGHT at bottom left, you will be able to connect correctly. If you see in black ENTER DEVICE, then you are not connected.
I do:
  • Connect to Spark wifi
  • GO4 app launched
  • Select SPARK
  • Press START FLIGHT
  • Camera view comes and it is connected
I have seen that on my iPad, I cannot do the same as for a android tablet where I can connect to the spark wifi directly from within the app.
On my iPas, if I do the same I go directly to camera view but it is disconnected.
There are differences between the android and IOS for connecting.
On android, I had each time to reset the wifi to default by pressing the battery until I get 3 bips, the spark start in 5.8 GHz and in my country these channels are forbidden.
This is utterly ridiculous that there isn't a fix out yet.
I tried android & iOS. iOS works flawlessly, android does not. [emoji53]
Agree in general, there is still some issues with cable connection (which is not official), but it is much more better.
akane13
