There is a mod to shot video in 25p?
If this is the same red DJI GO 4 MOD 2.0 (3027412)
225,76 MB
[packet name: dji.go.v5]
I have used for some months, fine with Phantom 4 Pro on different Samsung tablets, I can report Inspire 2 is not recognised at all.
I have to use another moded app to fly with Inspire 2, as those by NLD.
There are differences in behavior between one Samsung and another.
Don't write only Samsung Galaxy Tab S2, it says nothing, because is true and also not true!
Apart from the differentiation between 8 "and 9.7", there are at least 4 variants, and this is the cause of different behaviors and different repeatable problems.
Versions with and without 4G/LTE, and with different electronics, Chipset, CPU, GPU, have their importance and great influence on the behaviour.
Even the Android OS version could change the games.
These are the different versions I well know of S2, and each name begins with the suffix SM- (for example: SM-T815)
8 inch:
T710 [Wi-Fi], T715 [4G/LTE] and T713 [Wi-Fi], T719 [4G/LTE]
9.7 inch:
T810 [Wi-Fi], T815 [4G/LTE] and T813 [Wi-Fi], T819 [4G/LTE]
The most problematic, instable or unusable (and that is likely to drive you crazy) with DJI GO 4 apps, moded or not, and DJI remote controller are these: T713, T719, T813, T819.
Even when you are thinking to have finally discovered a tricky way on how make DJI GO 4 work and show your drone connected, you can aspect the next time or in the near future to be stopped again and it refuse to be connected, even after repeated restarts of all, tablet, RC and aircraft.
Seems to be a random instabilty, but this happens very frequently with the same discomforting results, ambiguous results, initially good, later not anymore, as if something happened in the cache memory or in the system preferences that create conflicts.
If you want to be ready to fly, without having these unacceptable obstacles stopping suddenly your DJI drone to ground, these Samsung tablet are probably the worst solution, despite their strong point of a good visibilty under strong light and sun.
Last but not least.
Those bad versions named here up, are also incompatible with the 4K movies of Phantom 4 Pro/Adv, the movies run jerkily.
Tested first of all with XPlayer, but also with other apps.
The best I have found for affidabilty, after months of use is the Galaxy Tab A 2016, it have also a bigger battery and you can use it many hours without charge it.
But unfortunately it's not good under sunlight, is a lot reflective also because of the air gap present between the LCD and the external glass, not laminated, it absolutely needs a hood or a covered place, in the shade.
For this aspect the Galaxy Tab S2 is far superior, with the 9.7" a step better then the smaller 8" version, it have a little more luminosity and more contrast, usefull under harsh lights.
So, if you want a good Galaxy Tab S2 for your DJI GO 4 app, these are the compatible versions:
Size 8": T710, T715
Size 9.7": T810, T815
AVOID ALL THE OTHERS!
All this said about these Samsung tablets is not related to the red DJI GO 4 MOD 2 app, it is probably valid for any GO 4 app, moded or not.
Reactions: koffe
newbie mavic pro user, i heard that mod 2.0 can be used to boost fcc on a mavic pro, i tried it and it seems work. but if i would like to fly with the newer stock dji go 4 app, which has the panoramic photo modes, will i still maintain fcc if i use the latest app instead?
many thanks in advance
Two questions on using mod 2.0 with mavic pro
i don't seems to see the pano modes and if i switch back to use official dji go 4 app, will i still maintain fcc?
many thanks.
You can't find them because you can only Download offline maps with DJI Mod lite and not with Mod 2. As far as i know.
this is the two screenshot of my mavic pro using different go 4 app, second one is mod 2.0, is it in fcc already?
first pic is when i use the original latest dji go 4 app, it seems going back to ce again!
my question is whether each time i use mod 2.0 to fly my mavic pro, it will switch back to fcc?
So is this MOD still compatible with latest update?
Noob question: can I use RTH with this mod or it should be avoided?
FYI, the mod lite version runs fine on my Galaxy Tab A 10.1 (2016) SM-T580- not rooted. I could access all the parameters and flew both in Atti and P mode with my Spark, using a remote control connected via OTG. The application is stable.
I see all Mavic pro's fly modes are now available, but didn't try them yet (will do asap).
V.
Reactions: Haggi
DJI GO 4 MOD 2.0
  • Auto enable screen rotation
  • Red Status and Nav Bars
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
  • Sphere Pano Support
  • DJI GO 4 Ver. 4.1.15
Downloads
DJI GO 4 MOD 2.0 - Download
DJI GO 4 MOD LITE - Download
Changelog
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
DJI GO 4 MOD 1.1.1
DJI GO 4 MOD 1.1
  • Fixed Google Maps
  • Keep Screen On Added
  • Added Auto 100% Brightness
  • Added Auto-Rotate
DJI GO 4 Mod 1.0
  • Initial Release
Tested Devices
  • Nexus 6P - Android 8.1
  • Nexus 6 - Android 8.1
  • Mate 9 - Android 8.0
  • HTC U11 - Android 7.1.1
  • Samsung S7 - Android 7.0
  • Sony Z3 - Android 6.0
Credits
PayPal: [email protected]
Does this sticky always have the most up to date version?
And will it work on a non rooted phone?
Thanks and sorry if this has been asked before. I have just read through a ton of posts and am now confused lol.
cliftonmatthew45yaw
