Litchi Limitation
i just used orbit as an example.
You cannot enter an Orbit Mission without taking off first.
Waypoints, you can take off and start the mission at the same time.
Your menu matches perfectly.
WAIT A MINUTE!
Your mission is on custom heading?
And it is facing 0° (north) at all times flying sideways.
Maybe that is it.
At each waypoint, change the heading slider and line up the nose of the Spark icon with the direction of travel.
Set the proper heading for all 5 waypoints and try again.
Or select AUTO (TNW) in the Hub settings menu
WAIT A MINUTE!
Maybe that is it.
Have done it both ways and same results. The little guy seems good about being able to fly at any orientation at the same speed. I did go out again and fly it again with pointed in the forward direction just to be sure one more time.
@pmshop - do you use AirData? If so, can you go into the Power/Volts and Amp section and look at "Flight Specific Full Range Amp Map"? See if at any time during a mission did you go above 6.1A (out of the green). That is what is appearing to be my limiter.
There is a slider setting in the dji app that controls the speed of the spark. Maybe that setting is causing the problem.
Reactions: pmshop
It is in remote control settings in the dji app. It is a slider called max flight speed settings.
It is a fun slider to play with because it can be used in conjunction with the other modes like tripod or sport.
You got it!
And this is on a Spark?
Never saw it before but know exactly where it "should" be.
Hmmmm....
Android???
Here’s mine from the mini4.
Johny parker
