Phone Wi-Fi connection
Malc
For some reason, the Spark doesn't appear on my list of wi-fi connections unless I turn the controller off and on a second time, is this normal? I am using an Android Samsung J3
  • Haha
Reactions: Bob Johnston
sparkflyJEF
how about the phone have you tried turning the wifi off & on ?
webvan
Are you in Europe maybe ? In Europe you can't connect using 5.8Ghz to the RC or the Spark, only 2.4 so it might be changing frequencies when it restarts. Normally the setting should stick for the next time you turn it on though.
Malc
Could be, but it happens every time
Andre Levite
WELL-TRUSTED MEMBER
Treasure Coast of Florida
how-to-spark.com
Yes. That is normal.
The Sparks wifi won't connect to phone and RC at the same time. So you need to turn off the RC for Spark to show up in phone's WiFi settings.
Malc
Thank you, as long as I am not being stupid
The only "Stupid Question" is the one not asked.....I refer to the Allegory of the Cave....Come into the Light
KST1P
So to follow the replies through. When you go into smart flight mode from RC . Does the phone connect directly to the drone or does it still go through the RC ?
twickers14
I have found that if you have an OTG cable (worth getting if you haven’t got one) and follow the sequence of turning on Spark and RC, wait for the green light on the RC and then connect up the OTG (into phone first then to RC) it all works pretty well. This is with an iPad though but can’t see why it wouldn’t work with a Samsung
Reactions: Sgt2231 and MarRoh
i love mtb
i have the problem to but i have an iPhone i just exit wi-fi in the settings then open it again and it pops right up
Malc
I have found the only way is to turn the remote off and on again, and it is always there on the second attempt
swindall
