They still haven't refunded my money and still nothing on eBay. Not sure why the have it back on Amazon.Its back in Amazon. Im really on the fence right now, cant decide between this one and the original portable charger
smatree weighs 750 gram and charges only 10 min faster per battery, sow i guess for the batteries themselfs its not that much less ideal.I guess you need to weigh up the pros and cons,
DJI version has a smaller capacity only 3 battery recharges vs 6
DJI can store the drone as well
Smatree charges faster, which means it uses a high rate, not necessarily the best for a Lipo
Smatree is heavier 1.1kg vs DJI 645g
Smatree has been reported to catch fire, although this is not conclusively proven
On balance I'd go for the DJI version if your walking/ hiking it would weigh less, if your driving you would be using a more dedicated car charger, so I'm not sure where you would use the Smatree.
In other instances I would probably get a normal powerbank that outputs 5v/3 amps and use a Rcharlance charger
i dont trust it either whats going on with them, no transparency what so ever. as with a lot of Chinese companies. dji at least has a name wich it doesnt want to mess up, but transparency is as bad as it gets. they claim it will be delivered within 5 workdays to the netherlands, but i'm reading from other consumers they have to wait till after newyear.They still haven't refunded my money and still nothing on eBay. Not sure why the have it back on Amazon.
Happy to read about your updates @Iasorey. I used my new smatree quite often and it is working great![]()
I think youre right. Once mine was full(4 red lights) i charged again my Samsung from 50 to 100%. Took an hour and just before it was full it went from 4 to 3 red lights. This morning i put it on the charger again and it went from 3 to 4 red lights within minutes. That seems to me impossible to be full. Ill give 3 hours more for now to see what happens.I checked mine with a voltmeter, it will stop. But I see, it took a bit longer, after the four dots are on. Charging stopped around two hours later, after the fourth lamp came on.
I think it is better to give the smatree and tge batteries fresh air. If I have to charge all three spark batteries, I have mine in fresh air. And I am a bit hypohondric... After the messages about burning Smatrees, I let it charge next me and check it in this 30-40mins.
I don't know? Is it the better idea to change for the improved version. Smatrees SP90 is out of stock everywhere. I am asking them, why...
This is what they answer:
»Our item is be improved with the charging time, and there is no stock now, please be assured.
Regards,
Smatree«
So we may have a not improved version now. So, give it back and wait for the new version? Is it improved in quality too?
What will you do?
its cheaper thats true, but 5 dollar isnt a dealbreaker. And it charges as slow as the smatree wich is 12 hours. the big con is all the wires and the Rcharlance you need to use. let alone putting all of this safe in your bag and be care full not to disconnect anything when you need something else in your bag. smatree makes all this a lot easier i think, but of course i didnt try your setup, so im biased.I'm using Ravpower 32000 mah power bank with 3 x 5v/2.4amp USB ports . I get 6 full battery charges out of this, either charging through the spark or using the Rcharlance usb charger.
The is the lightest most portable charging option I could put together for 3 batteries or 2 batteries and the controller
Charges the batteries in an hour using the Rcharlance, if your going to use another battery pack make sure the USB can output the required 2.4amps at the port
It's messier than the other pack based options with all the extra cables, but it has a lot of capacity about 118wh
I believe it's a cheaper option than both the DJI and Smatree
Portable Charger RAVPower Ace Series 32000mAh 6A Output Power Bank External Battery Pack (3-Port, 2.4A Input, Triple iSmart 2.0 USB, High-density Li-polymer Battery)
the safety concerns on the smatree i have too, so im checking it all the time while charging and i only charge it at a safe place where it cant harm much. so far it didnt produce any significant heat even when i charged 2 batteries and a phone in 1 time. if it keeps behaving like this im not too concerned about it. i just hope those bad reviews where faulty products or even better fake reviews (although i think theyre real).Your right , it's is a more cumbersome option, but I'd trust Ravpower power pack over Smatree from a safety perspective. I don't think I'd be using any of these charging options in the confines of a bag, just at the location and in the open as there is some heat generated
Not sure what the original price of the Smatree was , but the only reputable place I could find it, has it for USD 149, they have even removed it from aliexpress
New Smatree 92Wh Portable Power Station Charging Hub for DJI Spark Battery | eBay
they were on amazon for 65 dollar/euro, i got mine second hand for 50 euro so i went for it.
https://www.amazon.de/dp/B075K2VBNN/_encoding=UTF8?coliid=ITEWQLF37KA5H&colid=WXIHI1LJ6B8O&psc=0
