Tile tracker saved the day!
I am wondering....if it's recommended to turn off the blutooth on my phone when flying, how would slapping a bluetooth locator right on my Spark affect all the electronics. Is it only broadcasting when activated?
You can turn off-on BT on your device.
The question is about locator's Bluetooth, being on all the time, and so close to WiFi transmitter of the drone.
Exactly what I meant. Thanx!
Just had my first spark crash in the middle of the woods. About 0.5 miles away from where i took off. Completely my fault, went a little too low and hit some branches somewhere.
I have a little Bluetooth wallet tracker on it.
Even though it's short range, it was a LIFE SAVER.
find my drone got me to the general area but since there are trees and leaves everywhere, and the fact that I was able to eventually find it 5 ft off the ground stuck in a tree, I highly doubt it would have been easy to find.
The tile beeped the path and I was able to find it in 5 mins.
$20 bucks more than paid for itself right there.
Tile is a Bluetooth tracker. The tracking range is too small. I did not use it to track drones, but a tracker with GPS. So that I can track in a wider range without worrying about getting lost outside the tracking range.
The Tile trackers do have a use in close, we have found the cat a few times when she escaped her enclosure early on, before we built 'Alcatraz' for her, lol.
What IS really good too, and used a lot by larger aircraft pilots, is the newer Firehouse Technology ARC XL strobe.
It's a tad big for smaller aircraft, the Spark could handle one on a rear arm I guess, but the 1000 lumens (besides awesome for VLOS) makes it easy to spot if downed in vegetation / canopy or ground . . . plus it has a 90db alarm that goes off if the strobe is on and doesn't move for 4 minutes, hovering is fine to keep it inactive.
LynI816428
