Dave woods
- Join
- Oct 4, 2017
- Messages
- 122
- Age
- 66
the shaky video is a symptom of the 2 axis gimble and the wind I think same happened to my footage the wind was gusting up to about 20MPH yhough lol
when you were flying with the cable and autopilot was the flight telemetry updating, hight speed map etc as you can fly the spark with just the remote and no phone/tablet so it may not have been connected at all ?
ok so it was connected then, possibly if that works then it could be your OTG connector not making a good contact at all times I bought a couple of those very small ones that plug into the female end of the usb cable and they would keep disconnecting at random times, the only mode switch on the spark is the normal/sport buttonWhen I plugged in the OTG I got the exact same message as you do in GO4 accessory not supported and then I just cancelled it out.
Yes all telemetry was updating. I could see the map, the AC location, altitude and distance. I know this because I checked range both altitude and distance with RC to verify good connection beyond the proposed mission distances prior to flying the mission.
With the old P3 I had there was a toggle switch, I don't see a way to toggle the mode with the new controllers.
Ok I have just connected via OTG and although it does connect to the spark the video and photo button d DO NOT operate, I can confirm your findings that the spark is then able to be flown using the remote with telemetry and GPS shown, I then entered a zip line mission and pressed engage to be presented immediately with the RC dis connected message and not able to fly the mission. So although the aircraft connects to autopilot via OTG and can be flown Missions cannot be programmed and flown using the OTG cableThanks for your thoughts Dave I appreciate it. I am not inclined to accept that theory but I will consider it. The reason being is that it counts down to the mission but then as soon as it engages you get a RC override message and you are back in RC mode. This is not the case when the OTG is not connected, the missions have run fine. I am no expert but I will keep testing and post any findings. Thanks again.
Yes it's a strange one so it's supported partially but not fully I still believe it to be a symptom of the spark firmware and 3rd party apps as soon as DJI pull their fingers out and support waypoints in the SDK litchi will probably be my point of call for waypoint apps and autopilot for the follow and orbit missionsThanks again Dave, shows exactly what I am talking about. I did not notice the Video and photo issue, good catch. Again this is not the end of the world but I like the OTG as it forces 2.4 and I don't have to manually set it. Other then that I am fine flying without it. I am hopeful there is a patch to either allow OTG or set 2.4 as default. Regards
