This version is for Spark users who had his Spark patch by super patcher 2.01.
No longer notification and warnings from the app you entered Enhanced Warning Zones or warning zones.
Why a different Go4 App is needed for SuperPatched Sparks?
What is different from your recent upload "mod-45-spark-4.1.15-november-from-i" ?
Is this for Sparks on official .1000 firmware?
Thanks for this.
Can this Modded App force Virtual Joysticks when using OTG ?
Virtual Joysticks only appear when connected Wi-Fi direct from phone.
I need it for this set up. Much better wireless.
Reactions: max59
I can't help you, but love it when people think outside of the box.
Improvise, Adapt, and Overcome a situation.
Good luck with your endeavors. ?
Reactions: Torovolt
Gents, OTG works great with 01.00.0900, I made a new version of 4.1.15, new feature add voltage in goapp.
30 thays from now. install: download this file to phone or tablet Uploadfiles.io - mod-45 Spark 4.1.15 november from I.apk
delete old dji-go app, set phone or tablet(android) in airplane mode.
Install this version, sign in with : name A and password B.
after install, closed app, set wifi on and download offline maps you like.
check your settings again like rth altitude etc.
this version is 30 days available
greetz
Superpatch need AC running on fw .900
Should I downgrade the RC ?
Because my AC already running on fw .1000 also my RC on latest fw.
Wich RC fw version should I pick to control the AC on fw .900?
this is how to do , if you want a version with google maps
1. Go and get a Google Maps API license key. When I signed up, Google asked for a payment option, but gives you more than enough free use, that you won't get charged a thing for our use of Google Maps in GO.
2. Download latest modder from Bin4ry/deejayeye-modder
3. Edit the RunMe.bat file with Notepad ++ and place a pause in it. See graphic. This is for Windows. Save the RunMe.bat file as RunMePause.bat, so you keep the original.
4. Patch the latest 4.1.15 NoSecNeo APK (Go4 4.1.15: http://dankdronedownloader.co.uk/NLD_Downloads/DJI_Go_v4_4.1.15_NoSecNeo.apk )
5. Make sure you enable Matioupi's runtime_use_GoogleMap patch, and use your new Pause.bat file The APK will decompile, run all the patches and then pause before recompiling so then you can edit the AndroidManifest.xml file in the decompile folder.
6. edit the AndroidManifest.xml and enter your Google Maps key into line 61, overwriting the key thats already there. Leave the HERE maps key alone, since we want that to work also.
7. Continue on with the modder and let it compile
8. Install your new patched .apk. On your device, go to your /dji/ folder and create a subfolder and name it og_settings Inside that folder create a file called useGoogleMap and place it there. (I just created a .txt file and deleted the .txt extension) This is the key file. With this file there, Matioupi's patch will look for it upon start up of GO, and if it is there, you will have Google maps instead of HERE maps! (after initial startup and sign in, and then a restart of GO) I created the folder and placed the file after I installed GO, and ran it twice to do a quick configuration. Not sure if that is necessary, but it worked for me.
9. To switch maps, close GO, and I just renamed the og_settings folder, so GO skips it. Start GO and you now have HERE maps!
this is what I get after I do everything from the list and website. what did I do wrong.20191116_084247.jpeg
Blue version is the latest version we are talking about now, it's has more features and patches, also Offline HERE maps , you don't need internet any more.
After you do the superpatcher 2.02, you have the perfect combination.
Does this work with version 1.00.1000 fw?
App is install and works, but can't seem to make it stay on FCC, I think
TamikaT436
