That''s version isn't modified , you loose FCC power in europe and Mavic FlightModes On Spark. Also the app takes a lot of memory of your phone/tablet.
Just tried downloading this to my Samsung Galaxy Note 8 , it didn't download. I get a message saying app not installed. I have USB debugging and enabled developer mode on my phone.
Did you ensure it's set up for MTP under Networking/USB Configuration?
Yes. Tried file transfer as well as image transfer app won't load. I also tried Smart Switch and X-transfer, those don't work either.
I have the following app on my phone already
Skydio2
Dji go
Dji fly
3dr-Solo
I know that the regular Dji go 4 app will load, but I deleted it.
I also tried loading the original Mod 2, but no love as well.
Hi i hope its ok that i wrote this here
I have to ask if there an update for Android 10 and if its ok to work with this version on Android 10?
The old version like 4.1.15 doesn't work on android 10 on most phone's and tablet's.
but if you use the superpatcher, it doesn't matter which version DJI go4 you use, you get always FCC power, no NFZ and no Height limits. (even with Litchi).
My recommendation is use an older phone/tablet with android 9, use superpatcher once to get away of NFZ/Height and always FCC power. Then use 4.1.15 mod version(we are talking about here) with anoumous log in,no internet needed with offline HERE maps, FCC power, and mavic flightmodes for spark enable, OTG cable and if needed the DGI Go mod mission app for waypoints missions (
DJI GO mod missions (Spark and others) - Apps on Google Play) works well together with 4.1.15 mod
DJI GO 4 MOD 2.0
  • Auto enable screen rotation
  • Red Status and Nav Bars
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
  • Sphere Pano Support
  • DJI GO 4 Ver. 4.1.15
Downloads
DJI GO 4 MOD 2.0 - Download
DJI GO 4 MOD LITE - Download
Changelog
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
DJI GO 4 MOD 1.1.1
DJI GO 4 MOD 1.1
  • Fixed Google Maps
  • Keep Screen On Added
  • Added Auto 100% Brightness
  • Added Auto-Rotate
DJI GO 4 Mod 1.0
  • Initial Release
Tested Devices
  • Nexus 6P - Android 8.1
  • Nexus 6 - Android 8.1
  • Mate 9 - Android 8.0
  • HTC U11 - Android 7.1.1
  • Samsung S7 - Android 7.0
  • Sony Z3 - Android 6.0
Credits
PayPal: [email protected]
Well...this link in now broken. Any chance to reload the apk please?
Hi man. Thanks for the info. What is the superpatcher?
The purpose of this project is to liberate DJI aircraft from the limitations imposed by DJI. DJI Super-Patcher allows new features/abilities, unlocks arbutrary limitations, and allows DJI aircraft to be customized far beyond what is allowed by the factory firmware.
Super-Patcher works differently than other methods for unlocking firmware. It is not a modification that mixes old firmware with new firmware. Super-Patcher patches the flight controller module that is already installed on your aircraft. This ability to patch the actual firmware itself means that new capabilities are unlocked. Super-Patcher has been tested and verified. You can trust that it has been proven but you still use at your own risk.
While Super-Patcher removes the default altitude and GeoZone limitations, that does not mean it is safe or legal to do so in your area without proper authorization. DJI Super-Patcher is meant to allow responsible pilots with the correct authorization to fly in areas and to heights that DJI does not offer a reasonable method or any method at all to unlock. It is solely the responsibility of the pilot to ensure local laws and regulations are adhered to and to fly safely just like with any other aircraft.
PLEASE FLY RESPONSIBLY!
Super-Patcher has been designed to be used by the average joe and much of the design and development has been to make the process as easy as possible. It only requires very basic computer skills, such as clicking buttons and navigating to a folder using the file explorer. Super-Patcher is a batch script that runs natively on all Windows PCs and all dependancies are downloaded automatically by the program. No prior set up is required. Super-Patcher is interactive and walks the user through step-by-step dynamically based on user selections. It doesn't get much easier than this.
  • Remove height limitations
  • Remove NFZ and GeoZone limits
  • Enable Galileo satellite reception
  • Optionally enable full time FCC or boost mode with jkson_fcc_mod by jkson5 built in Spark***(NEW!)***
  • Optionally disable external aircraft LEDS lighting for stealthy night flying
    Thanks to Brett brett8883/DJI_Super-Patcher
Reactions: Alev
Souds awesome. Only I cant seem to find the instructions on GitHub. I found the sourcefiles etc. Where can I see the step by step instructions you referred to?
Thanks!
Thanks!
Toward the bottom of the main page, there is a video and (thankfully) written directions. It is extremely easy.
Reactions: Alev
KingEggles
