Stopping the props mid-flight
rich777
Hi everyone
Has anyone ever thought there must be a faster way of bringing the drone down and has anyone here been brave enough to stop the props mid-flight by pulling the sticks in and down and then just restarting them closer to the ground.
I wonder if when it was falling the props turning the other way would kind of slow the speed down almost like autorotation on a helicopter. But I don't want to be the first to try it ha.
Reactions: turbo_ek
rich777
Thanks for letting me know. That's a shame sounds like it would be fun
Spark 317
Well known member with a Spark and a Mavic Air 2.
Indiana, USA
I actually tried it and can confirm that it doesn't work.
There is a faster way that has been described as a reverse double helix.
I copied these instructions from another post....
Left hand goes down and to the left
Right hand goes up and to the left.
It will look goofy but seriously in sport mode you’ll be close to sustaining 9mph down.
I have tried this and it works but the Spark is flying around in a circle of sorts so make sure you have plenty of airspace to do this and not hit anything.
Reactions: rich777
rich777
Thanks for the advice I will try that next time I get a bit of height.
Speedmeister
Spark are not designed for fast vertical landing. I usually do a moving forward with decreasing altitude when landing my spark.
Reactions: rich777
NRRTRAINS
Staten Island, New York
even if it did work the spark would most likely start to go end over end or drop like a rock or come down on the back end because of the battery having the most weight . at 400' how long do you think it would be before it hit the ground ?
Reactions: rich777
Bob Johnston
Not very long
Hi everyone
You first! LOL.
Reactions: rich777
Spark 317
Indiana, USA
Did some number crunching thanks to Google...
The Spark (.3 kg) will impact the ground at 176 kph or 109 mph from a height of 122 meters (400') and take 4.99 seconds of butt puckering terror to the time of impact.
Northwood Mediaworks
Spark & Mavic Air 2
Northern Ontario, Canada
northwoodmediaworks.com
I find this works best also. My final approach is airplane style often.
Reactions: rich777
Putz
I had an older cheaper drone that let you cut the motors off at anytime. At about 200ft if I stopped the motors, they would free spin and the spinning created enough drag and lift to let the thing land fairly soft. Enough so that I've done it numerous times without it breaking. The spark is a lot heavier and smaller, I would never think of trying it if I could, but I wonder if it would the same thing?
Reactions: rich777
Spark & Mavic Air 2
I doubt it, the thing would drop like a rock. Gladly the command has been removed from the aircraft.
Reactions: rich777
Speedmeister
The spark shuts its motors down when it is beyond its maximum flight degree angle. Flip the spark 90 degrees on anyside and the motors shutdown.
Reactions: rich777
rich777
I I'll put the power on at 1.6 seconds before impact just to flare it out. should leave me 4 inches off the ground[emoji23]
rich777
Same
luisg1095
