canalrun
- Join
- Feb 10, 2018
- Messages
- 31
- Age
- 65
It'll fit if it's not in a case. You can fit a mobile device up to the size of an iPad Mini.
Thanks for your reply. I will try those configuration settings in Android.
I am a little confused. I'm currently using a Samsung Galaxy S5 and it fits easily in landscape mode within the controller.
The two Apple options I am looking at are and iPhone 6+ or an iPad Mini 3.
I found the following comparison specs. Beneath each device is the device size.
If I use a ruler to measure my Spark RC with the device arms fully extended, I would guess I could fit a 177 mm (7 inch) device between the controller arms. I would want the device to be in landscape mode. If I look at the specs, the width of the Samsung in landscape is 142 mm, the width of the iPhone 6+ is 158 mm, but the width of the iPad mini 3 is 200 mm.
According to my measurement the iPad mini 3 would be too wide in landscape mode.
You mention above that the iPad mini 3 will fit in the controller. Is this in landscape mode? Do you use an iPad 3 mini with the controller? Have you modified the controller? Are my measurements just wrong?
Thanks,
Barry.
