For the low cost of factory props it's not worth the risk. Actually, own/owned of 6 DJI platforms and have NEVER changed the props on any of them.Sticking with factory props. Too much to loose if they fail
Nah...just trying to save you a headache down the road. If a malfunction were to happen not related to the props and you had to submit a flight log to DJI for a warranty claim the "knock off" props could become an issue. I'm not the authority on flight logs, but @msinger has posted about this back on the Phantom forums a while back.I'm apparently a bad driver!![]()
In see wear on the leading edge of my props closest to to the mounting point on all my props. Maybe 4 hours of flight time on them. No crashes, but some landings in short grassFor the low cost of factory props it's not worth the risk. Actually, own/owned of 6 DJI platforms and have NEVER changed the props on any of them.
Yes, I noticed that sort of wear on my Mavic. Haven't flown my Spark nearly as much, but being that the props are similar to the Mavic I'm sure they'll wear soon.In see wear on the leading edge of my props closest to to the mounting point on all my props. Maybe 4 hours of flight time on them. No crashes, but some landings in short grass
That was kinda the message I was trying to convey to the OP. OEM props only cost a measly $9, compared to the cost of the Spark ($500+) $9 is nothing. DJI forums are filled with horror stories from pilots flying with "knock parts". The eBay seller where the OP bought the props also sells this well known drone related item:When it comes to props and batteries it is only OEM for me. I realize there are some good replacements but just the same there is some shoddy workmanship with some replacement parts.
Definitely get yourself a landing pad. They are super cool and work wonders.In see wear on the leading edge of my props closest to to the mounting point on all my props. Maybe 4 hours of flight time on them. No crashes, but some landings in short grass
